Failure of a planned failure - Pontiac Silverdome 1
That's not too uncommon, look for "Failed Demolition" or similar terms on YouTube.
I'm glad I'm not the one that gets assigned to go check out those charges and see why they didn't go off!
Was going to post this, thank you for doing it fitst.
Going to be hard and unsafe to go back into the building (under the failed dome!) to investigate, remove the unexploded-but-still-dangerous explosives now present, add more in those holes and joints, rig them for blasting, and then get back down.
If you don't remove them, then you have to find them and remove them from under the demolished rubble AFTER the second blasts go off.
The old dome isn't there- there's no 'under the dome' to contend with.
It also appears that the explosives detonated as planned, they just didn't cause the structure to lose enough stability to bring it down.
"Rick Cuppetilli, the executive vice president at Adamo, told the newspaper that 10 percent of the explosive charges in eight key locations failed to detonate due to wiring issues that crews are investigating..."
I stand corrected. My previous post was based on watching the video.
Interesting to go back in without a 'really big hardhat'. I recall going into a building in pending collapse and had the Building Official stay outside to call 9-1-1 if necessary.
Dik
I guess you could describe this as a sort of "crowd-sourcing" approach to bringing down the Pontiac Silverdome:
Explosives didn't work, maybe rocks will take down the Silverdome?
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
As many times as the Lions imploded in there, maybe it just can't be 'ploded no mo'.
Yea, so he blew a dam instead and the bridge became collateral damage...
Irvine, CA
Siemens PLM:
UG/NX Museum:
In the original design, the "steel columns" don't appear to be used to support the concrete structure but only as a component of the roof. At some point the roof structure was modified to include a ~cantilever mechanical perimeter roof~, which looks quite robust. If they had had any success, they might only have brought down the added roof section.
Cross-Section
Link
Hinged Columns/Tie-downs which allow compression ring to move Engineering News Record October 1, 1981, p. 76.
During Construction
Roof Addition
Source
Looks like they were able to successfully complete the demolition today. Whew.
This happened to be in my "backyard". On the radio this morning, the CEO of the demolition company that said he was not in the business of entertaining onlookers with a successful demolition, his job was to simply demo the building. He explained that the main explosives designed to sever the columns went off, but the kicker charges did not due to a wiring failure. Apparently they double checked the wiring and it was intact (which I am not sure how you verify after detonation) but suggested that it could be defective wiring. He also said that they could have demo'd the building by mechanical means, but they came to an agreement with the city to implode it as a way of drawing attention to the potential for redeveloping the site.
Between the Lions and the building demo, seems like nothing ever went right at that place.
If the goal was to draw attention to it, their plan worked. If it went off without a hitch, we wouldn't be talking about it.
I would call this a success.
I thought those systems did a low-voltage check of the entire wire-out to ensure this sort of thing didn't happen...
Dan - Owner
URL]
MacGyver,
They may have been using outdated equipment.
I don't know if all the links will play, but most seem to be YT ones, but this has clearly prompted this article.
For those that like that sort of thing.....
Thanks for posting that LittleInch. Some of those were very impressive.
