FEMAP API - Extrude surface error 1
Brick6
Marine/Ocean
May 8, 2013
5
Dear all,
I'm writing an Excel VBA comment, which should automatically build a plane with stiffened panels. In drawing the curves, I succeed, however when I try to extrude these curves I cannot get my code working. Can somebody check what I am doing wrong?
My excel file:
Code:
Dimensions (mm)	L	B
Web	366	12
Flange	16	125
Number of stiffeners	3
Deck longitudinal spacing	800
Panel width	2400
Web frame spacing	4500
My code:
Code:
Sub butBuilt_Click()
    Dim rc As Integer
    Dim ID As Integer
    Dim sID As Integer
    Dim app As Object
    Set app = GetObject(, "femap.model") 'Set model
    Dim WS As Worksheet
    Set WS = ThisWorkbook.Worksheets("Sheet1")
    rc = app.feDeleteAll(True, True, True, False) 'Delete old stuff
'Plane
    'Point #1
    Dim P As Object
    Set P = app.fePoint
    P.x = 0
    P.y = 0
    P.Z = 0
    ID = P.NextEmptyID
    rc = P.Put(ID)
    'Point #2
    P.x = WS.Cells(9, 3)
    P.y = 0
    P.Z = 0
    ID = P.NextEmptyID
    rc = P.Put(ID)
    'Line #1
    Dim Line As Object
    Set Line = app.feCurve
    Line.StdPoint(0) = P.PrevID
    Line.StdPoint(1) = P.NextEmptyID - 1
    ID = Line.NextEmptyID
    rc = Line.Put(ID)
'Web
    Dim i As Integer
    For i = 1 To WS.Cells(6, 3)
        'Point on plane
        P.x = WS.Cells(7, 3) / 2 + WS.Cells(7, 3) * (i - 1)
        P.y = 0
        P.Z = 0
        ID = P.NextEmptyID
        rc = P.Put(ID)
        'Point height web
        P.y = 0
        P.Z = WS.Cells(3, 3)
        ID = P.NextEmptyID
        rc = P.Put(ID)
        'Line web
        rc = Line.Put(ID)
    Next
 'Flange
        'Point west of flange
        P.x = WS.Cells(7, 3) / 2 + WS.Cells(7, 3) * (i - 1) - WS.Cells(4, 4) / 2
        P.y = 0
        ID = P.NextEmptyID
        rc = P.Put(ID)
        'Point east of flange
        P.x = WS.Cells(7, 3) / 2 + WS.Cells(7, 3) * (i - 1) + WS.Cells(4, 4) / 2
        P.y = 0
        ID = P.NextEmptyID
        rc = P.Put(ID)
        'Line flange
        rc = Line.Put(ID)
    Next
'Create 3D model
    Dim curveSet1 As Object
    Set curveSet1 = app.feSet
    rc = curveSet1.Select(4, True, "Select") 'Select all curves
    curveSet1.ID = 1
    Dim dof(3) As Long
    Dim vdof As Variant
    dof(0) = 0
    dof(1) = -1
    dof(2) = 0
    vdof = dof
    rc = app.feSurfaceExtrude(1, 4500, vdof) '<-- does not work..
'Check
    If rc = -1 Then
        j = app.feAppMessage(1, "Done.")
    Else
        j = app.feAppMessage(3, "Failed.")
    End If
    app.feViewRegenerate (0)
End Sub
Any help is welcome!
Ok, solved it myself. Apparently there was something wrong with the datatype. The thread can be deleted if necessary.
Code:
'Create 3D model
    Set curveSet1 = app.feSet()
    rc = curveSet1.AddAll(4) 'Select all curves
    curveSet1.ID = 1
    Dim Dof(3) As Double
    Dim vDof As Variant
    Dof(0) = 0
    Dof(1) = 1
    Dof(2) = 0
    vDof = Dof
    rc = app.feSurfaceExtrude(1, 4500, vDof)
