FEMAP display of loads & constraints refresh 1
LeonardoBer
Aerospace
Oct 22, 2020
19
Hello everyone.
For some reason FEMAP doesnt want to refresh its display of loads & constraints. When i activate any loads/constraints set, the display is stuck on one particular set. Even if I create a new load set, I am not able to see it because the model only displays that one load set. I am only having this problem with one model, other models seem to update the display just fine. Anyone else have had this issue?
Hi
Could it be that you under "Visibility"-"Load/Constraint" have selected a specific Load and Constraint Set, instead of the Active Set?
I think that I have done that by mistake at some time.
Best regards
Thomas
Yes, that was one of my frequent "rookie" mistakes.
With FEMAP, I was still making those kinds of mistakes after 2 years of using it... :(
ThomasH, that was absolutely it! I didnt even know about this feature in femap.
I had been working with the model all this time since the original post, without being able to see the loads that I am applying- what a pain. Thanks alot.
surely ThomasH's post is worth an LPS ?
Little Purple Star, beside "great post" ... the post exactly answered your question ... that deserves recognition.
