SolidworksFan
- Feb 7, 2012
- 25
I have been posting in the FEA section by mistake.
OK folks by now you have figured out that I a brand new to FEMAP. This software is making me feel like a total idiot. I have been thru all of the examples and I still can not get off of the ground. I am trying to build a very simple model, a plate with 4 mounting holes.
For practice, I want to build the model in FEMAP not import it. So I used Geometry/Surface/Corners and made the surface no problem.
The next item I tried was to add a hole in the corner. I used Geometry/Curve-Circle,diameter and created a sketch of a hole in the corner.
Now I want to turn the sketch into a hole. I am using Example 4 as reference. I tried Geometry/Boundry Surface/From Curves, picked the circle, OK, then cancel.
Then I tried, Geometry/Surface/Extrude picked the hole curve, choose the Remove radial button, then OK, Cancel.
Problem 1: The hole curve does not look like a hole!
Problem 2: I typed in the wrong number for the location of the hole and need to move it. How do you edit the location and diameter?
Problem 3: I also want to pattern this hole. I see the pattern choice in a solid but not in a surface.
Problem 4: Say I need to change the overall size of the plate due to a design change. How do you edit the size of the surface.
I have not defined the material yet. That was going to be my next step after building the geometry. I have figured out how to assign material.
All of this seems like it should be 3rd grader work but my mind must be stuck in Solidworks land. FEMAP can not be this difficult to use! I blame the operator (me) not the software.
Please no more replies suggesting I go thru the examples. I have and I am truly trying to figure this stuff out.
Thanks in advance for the assistance.
Frustrated to the point of implosion,
RS
RS
