I have an extruder motor that has rating of 700HP 500vdcARM 300v/150vdc.field 8.9a/17.8 amp field @ 1750RPM. Currently under load we have 800amps on the armature @1750RPM. We are using 300vdc.field EXC Shunt.The manufacture say the motor is capable of 2400RPM. If we purchase a field weaking board. My first question is what will happen to arm.current at the same load go up or down and why?My 2nd question is where can I get some mathematical formulae on dcmotors because I measured the field resistance before installation and got 26ohms on the field.Using ohms law does not apply 300v/26ohms does not equal 8.9amps as rated on nameplate.
