Firetube Boiler
mansari14
Chemical
Apr 26, 2013
4
Can we weld two tubes together to meet the total length requirement? We have fire tube boiler operates at 12 bar pressure. The available tubes are short in length by a meter, therefore we intend to join two tubes together in a way to fit to the required size. If it is allowed by the code, what considerations one should keep in mind?
You can buttweld up to 9 short pieces of tube together to make one tube
If anyone asks for your justificatin, say that "someone on the internet told you it was acceptable ;)
Regrds
MJCronin
Sr. Process Engineer
Dammit, I was hoping to use 10 :)
Sorry, ... the rules are the rules ...
MJCronin
I'm not familiar enough with Section I to answer the question, but my guess is that this is likely allowed. Check with your A.I.
There is a false perception that anything that looks like a poor design practice is expressly prohibited by ASME Code, but the reality is that many things that would be considered a poor practice (e.g. nozzles located directly on weld seams, nozzles located in the knuckle region of a head, nozzle attached with partial penetration welds, vessels fabricated out of more individual plates than is absolutely necessary, repads overlapping weld seams, square/rectangular repads with sharp corners, repads thicker than the vessel wall thickness, etc.) are perfectly acceptable per ASME Section VIII.
-Christine
During the manufacture of a heat exchanger I did not approve a shell made up of 2 sections of NPS 12 to complete the total length of 2000 mm.
I was not a serious manufacturer.
During manufacturing some errors can occur that require user approval to continue with the work. But I never saw a nozzle on a longitudinal/circumferential weld on the design drawing, for example.
Follow 3.3.4.9 part.3 of NBIC, repair of firetube boiler.
