Flange brace force
ajnweb
7
I have a question regarding the flange brace force on a beam. Lets say I have a beam in bending due to gravity loading, the flange brace force on the compression flange is 1% to 2% of the flange force (moment/depth). So I have applied a gravity load to a beam and now have a lateral load to resist, and since we all know that we cannot apply a gravity load and get a net lateral load, where does the equal and opposite force to the flange brace force come from? Is it taken by the flange brace back up to a lateral beam that is attached to the tension flange, and is it the tension flange that then provides the equal and opposite force? Thank you for any and all responses.
On the issue of all of the beams going one way or canceling:
From Yura's stability conference, when beams are tied together and they all laterally-torsionally buckle at the same time (they are all loaded to this point and LTB is the limit state), they will ALWAYS all go the same direction. If you have 9 beams and five of them want to go one way and 4 of them want to go the other, there will be a slight tilt towards the direction of the 5 and the 4 will "change their minds" and go along with the rest.
I would definitely check out the beam bracing provisions. The 9th ed. ASD doesn't have these, as you know. The 2% rule is a rule of thumb with no real theoretical base to my knowledge. It tends to be conservative which is why it's so popular along with the ease of use. Going with a more rigorous analysis with the LRFD code may save you some material at the expense of a headache.
Thank you to everyone for responding, all of the answers have been a great help.
As a follow up to UcfSE's post - the 2% loading "rule of thumb" is generaly conservative for the strength provisions of the LRFD code (which generally run in the 1% range) however it is the STIFFNESS considerations and requirements that typically govern bracing design - in which case ONLY looking at a 2% strength condition can grossly underestimate bracing requirements.
