kimseunghee
The normal closed contact(low level) of float switch is connected to relay in the starter but relay does still energized when level reaches low. The relay is driven by AC220V. I swapped relay and circuit with DC24V instead of AC220V, then the realy is working(drops).
The contact is laid with other signals in the same mulitcore cable at length of 300 meter.
How could I check in order to resolve ? I would like to maintain AC220V circuit. Attached please find sketch for the above.
