PaulKraemer
- Jan 13, 2012
- 155
I am working on an application where I will have to supply compressed air to a particular component. Manufacturer specs for this component say that its worst case maximum consumption of air would be 0.5 CFM at 75 PSI. Please correct me if I am wrong, but if I assume the air is at standard temperature and humidity, I believe I would relate CFM to SCFM as follows:
0.5 CFM * (75 PSI / 14.7 PSI) = 2.6 SCFM
I will actually have to supply compressed air to five of these components. If my assumption above is is reasonable, and my calculation is correct, this would mean my maximum demand for all five components would be 2.5 CFM, or 13 SCFM.
I'd like do determine whether air line with a 4 mm inner diameter will be adequate to deliver this volume of air. If I had to run a single 50 foot long air line to a single manifold that fed all five components, I am wondering if anyone here can tell me how I can calculate either the SCFM or the CFM @ 75 PSI that this air line would be capable of delivering.
If my assumptions are misguided and my calculation is incorrect, or if I am over-simplifying or over-looking important details, please let me know and pardon my ignorance.
Thanks in advance,
Paul
Thanks in advance,
Paul
