flow of fluids and gasses 1
Danfossegypt
Industrial
Apr 3, 2004
26
hello engineers,
can anyone help me to find a book or any document to give me the laws of flow of liguids and gasses and the bassic type of pumps ?
I know of no books that cover both subjects.
I know of no books that cover basics because those subjects are not basic. Sometimes, a chemical engineering book might have review chapters or small chapters dealing with both subjects.
I think your best option is to Google and pick the information off the net, being careful to weed out the erroneous information that can be found on the internet. Make sure the sight is reliable source and verify anything with at least 2 or more other sources before accepting anything.
PUMPDESIGNER
My suggestion would be. Cameron Hydraulic Data Handbook
Subjects covered
Hydraulic principles
Friction Data
liquids density, SG, vapour pressure, viscocity etc
steam data
electrical data
formulae
pump selection guide
Bill
I reccomend you try this text book from Parker Hydraulics. Thay also have other books directly related to pumps.
find it at
Design Engineer's Handbook Volume 1 Hydraulics
Bulletin 0292-B1
ISBN 1-55769-043-X
Fan and pump laws are basically the same. Just different density, viscosity etc.
Fan laws are also identical.
Try FETA UK which is a fan manufacturers association. They publish guides on fans and characteristics which at last count were free. Also Woods Ltd. a UK company (Now Flakt Woods) publish various excellent books on fans. If you are in an area that you are able to buy a Woods Fan, then the local sales rep might be able to wangle a book for you. (I did)
Drapes
As you appear to be from Danfoss, you might be interested in an excellent publication by an independent UK trade association (GAMBICA) that has published a booklet called "Variable Speed Driven Pumps". It is easy to read and, as it is independent, there is no manufacturers bias. As a VSD manufacturer, we have even put this on our own intranet for our own people (with permission of course) to read. and then click on "publications" and scroll down to find the pdf.
