Forcing an Excel chart to have equal X & Y scales 1
Denial
933
AU
This post is a long-overdue update to a 2005 discussion on this forum. See thread770-141275. The discussions ended up focussing on how to achieve equal X and Y scales in Excel's XY-Scatter charts, and the final result was a passably-reliable VBA subroutine.
Over the years since then I have used that subroutine numerous times, and in so doing I have gradually made it more reliable and more robust. The latest version of this subroutine is presented below. I hope it will help any others who have wrestled with this problem.
Code:
Sub GiveActivePlotEqualScales()
'  Changes the X and Y scales of an Excel XY-Scatter chart by
'  exactly the right amount to result in the two scales being equal.
'  The chart, which can be embedded in a worksheet or can be on its
'  own chartsheet, has to be "active" when this subroutine runs.
'  The original subroutine was developed by Jon Peltier, and placed
'  on his [URL unfurl="true"]www.peltiertech.com/Excel/Charts/SquareGrid.html[/URL] web page.
'  A modified version of this was placed on the "Engineering
'  spreadsheets" forum of the Eng-Tips web site ([URL unfurl="true"]www.Eng-Tips.com)[/URL]
'  by contributor Panars in December 2005, in thread 770-141275.
'  Two other EngTip-ers, Electricpete and Denial, then made further
'  modifications to it.
'  For charts with at least one axis displayed there were still some,
'  seemingly random, circumstances under which the resulting scales
'  would not be adequately equal.  I believe that this updated
'  incarnation of the subroutine has rectified this problem, as well
'  as introducing a few more refinements.
'  The subroutine will not run on a protected worksheet unless the
'  protection allows the user to "edit objects".  However a user who
'  can "edit objects" can also mess up the plot in various ways, so
'  the protection would seem to be somewhat pointless.
Dim s As Series, PointsList As Variant, PointCount As Long
Dim PlotInHt As Double, PlotInWd As Double
Dim HaveXaxis As Boolean, HaveYaxis As Boolean
Dim PlotName As String, TypeOfPlot As Long, SubtypeOfPlot As Long
Dim IsEmbedded As Boolean
Dim Xmax As Double, Xmin As Double, Xdel As Double
Dim Ymax As Double, Ymin As Double, Ydel As Double
Dim XmaxData As Double, XminData As Double
Dim YmaxData As Double, YminData As Double
Dim Xpix As Double, Ypix As Double
Dim Distort As Double, Distort_pc As Double
Dim CycleCount As Long, MaxCycles As Long
Dim AxisControlling As String
Dim MoveDist As Double, Shift As Long
Dim Margin As Double, Temp As Double
Const SubName As String = "GiveActivePlotEqualScales"
'  Determine whether the active chart is embedded in a worksheet or
'  is a sheet in its own right.  (If the activesheet's type is not
'  a worksheet, assume that it is a chart.)
IsEmbedded = (ActiveSheet.Type = xlWorksheet)
With ActiveChart    'The "End With" for this is at the very end of the subroutine.
'  Get various properties of the chart.  Check chart type.
PlotName = .Parent.Name
TypeOfPlot = .Type
SubtypeOfPlot = .ChartType
If TypeOfPlot <> xlXYScatter Then
    MsgBox "Scale-equalising macro is intended only for an XY Scatter chart.", , _
           PlotName & " / " & SubName
    Exit Sub
End If
'  Get presence/absence for each axis.
HaveXaxis = .HasAxis(xlCategory)
HaveYaxis = .HasAxis(xlValue)
'  Determine the extreme X and Y values of all the data points,
'  looping through all the data series on the chart.
'  Note that VBA generates an error if we try to do anything with
'  an empty series:  hence the need for the "on error" statements.
Xmin = 9.999999E+100:   Ymin = Xmin:   Xmax = -Xmin:   Ymax = Xmax
PointCount = 0
If IsEmbedded Then
    For Each s In ActiveSheet.ChartObjects(PlotName).Chart.SeriesCollection
        On Error Resume Next
        PointCount = PointCount + s.Points.Count
        PointsList = s.XValues
        Xmax = Application.Max(Xmax, PointsList)
        Xmin = Application.Min(Xmin, PointsList)
        PointsList = s.Values
        Ymax = Application.Max(Ymax, PointsList)
        Ymin = Application.Min(Ymin, PointsList)
        On Error GoTo 0
    Next s
Else
    For Each s In .SeriesCollection
        On Error GoTo 0
    Next s
End If
If PointCount <= 0 Then
    MsgBox "Chart contains no data points.", , PlotName & " / " & SubName
    Exit Sub
End If
'  Expand these maximum and minimum values very slightly, so that
'  line segments running along the very edge of the graph area
'  do not get missed.  If the chart sub-type is "smoothed"
'  use a bit more expansion, to allow for the smoothed edges to
'  extend beyond the actual data points.  (The sizes used for
'  these "margins" are no better than a guess on my part.)
Margin = 0.005
If SubtypeOfPlot = xlXYScatterSmooth Or _
   SubtypeOfPlot = xlXYScatterSmoothNoMarkers Then Margin = 0.04
Temp = Margin * (Xmax - Xmin)
Xmax = Xmax + Temp
Xmin = Xmin - Temp
Temp = Margin * (Ymax - Ymin)
Ymax = Ymax + Temp
Ymin = Ymin - Temp
'  Record these max & min values for later use.
XminData = Xmin:   XmaxData = Xmax:   YminData = Ymin:   YmaxData = Ymax
'  If we have an X axis, find out what MajorUnit would auto-apply.
If HaveXaxis Then
    With .Axes(xlCategory)
        .MaximumScaleIsAuto = True
        .MinimumScaleIsAuto = True
        .MajorUnitIsAuto = True
        Xdel = .MajorUnit
        .MaximumScaleIsAuto = False
        .MinimumScaleIsAuto = False
        .MajorUnitIsAuto = False
    End With
    If Xmax = Xmin Then Xdel = 0
End If
'  If we have a Y axis, find out what MajorUnit would auto-apply.
If HaveYaxis Then
    With .Axes(xlValue)
        Ydel = .MajorUnit
    End With
    If Ymax = Ymin Then Ydel = 0
End If
'  If have both X and Y axes, use the larger MajorUnit for both.
If HaveXaxis And HaveYaxis Then
    If Ydel >= Xdel Then
        Xdel = Ydel
    Else
        Ydel = Xdel
    End If
End If
'  For directions with axes, round the minimum values down to be
'  multiples of the axis's MajorUnit.  Round only the "minimum"
'  values, since these are the ones that serve as the base for the
'  markings along the axes.  (And if we also do it for the maximum
'  we risk overconstraining our problem.)
'  Also, set the MajorUnit.
If HaveXaxis And Xdel <> 0 Then
    Xmin = Xdel * Round((Xmin - 0.5 * Xdel) / Xdel)
    .Axes(xlCategory).MajorUnit = Xdel
End If
If HaveYaxis And Ydel <> 0 Then
    Ymin = Ydel * Round((Ymin - 0.5 * Ydel) / Ydel)
    .Axes(xlValue).MajorUnit = Ydel
End If
'  Get the dimensions of the part of the chart used for the actual
'  graphing, then use these to calculate the present values of the
'  relative scaling factors in the X & Y directions.
PlotInWd = .PlotArea.InsideWidth
PlotInHt = .PlotArea.InsideHeight
Xpix = (Xmax - Xmin) / PlotInWd
Ypix = (Ymax - Ymin) / PlotInHt
'  We can now set about equalising the scales.  In an ideal world
'  this would be a simple, single pass, exercise.  But it turns
'  out that, for a chart that has any axes displayed, a change to
'  the defined extents of a displayed axis will sometimes change
'  the chart's InsideWidth or InsideHeight properties.  I cannot
'  find a way to predict when this will or will not happen.
'  This behaviour a major PItA.  It requires us to adopt an
'  iterative approach.  Implement the iterations with a For—Next
'  loop, and set a fairly low limit on the maximum number of
'  iterations allowed.  (But not too low:  I had one chart which
'  required 9 iterations to achieve adequately equal scales.)
MaxCycles = 15
For CycleCount = 1 To MaxCycles
    '  Adjust one of the scales in an attempt to achieve equality.
    If Ypix < Xpix Then
        '  X DIRECTION CONTROLS THE SIZE OF THE CHART.
        AxisControlling = "X"
        'Set the X-axis extents to the data's extents.
        .HasAxis(xlCategory) = True
        .Axes(xlCategory).MinimumScale = Xmin
        .Axes(xlCategory).MaximumScale = Xmax
        If Not HaveXaxis Then .HasAxis(xlCategory) = False
        '  Recalculate the scaling factors, which might have changed.
        '  Calculate the value of Ymax so that will result in
        '  the same value for the scale of the Y-axis as we
        '  have just defined for the scale of the X-axis.
        Ymax = Ymin + Xpix * PlotInHt
        '  The available space in the Y-direction will be greater
        '  than what is needed by the actual graphing.  Attempt
        '  to position the graphing centrally in this space.  If
        '  the chart has its Y-axis displayed, then any shift
        '  must be a multiple of the MajorUnit.
        MoveDist = 0.5 * (Ymax + Ymin - YmaxData - YminData)
        If HaveYaxis Then
            Shift = Round(MoveDist / Ydel, 0)
            Ymin = Ymin - Shift * Ydel
            Ymax = Ymax - Shift * Ydel
        Else
            Ymin = Ymin - MoveDist
            Ymax = Ymax - MoveDist
        End If
        '  Set the Y-axis extents to these calculated values.
        .HasAxis(xlValue) = True
        .Axes(xlValue).MinimumScale = Ymin
        .Axes(xlValue).MaximumScale = Ymax
        If Not HaveYaxis Then .HasAxis(xlValue) = False
    Else
        '  Y DIRECTION CONTROLS THE SIZE OF THE CHART.
        AxisControlling = "Y"
        '  Set the Y-axis extents to the data's extents.
        '  Calculate the value of Xmax so that will result in
        '  the same value for the scale of the X-axis as we
        '  have just defined for the scale of the Y-axis.
        Xmax = Xmin + Ypix * PlotInWd
        '  The available space in the X-direction will be greater
        '  the chart has its X-axis displayed, then any shift
        MoveDist = 0.5 * (Xmax + Xmin - XmaxData - XminData)
        If HaveXaxis Then
            Shift = Round(MoveDist / Xdel, 0)
            Xmin = Xmin - Shift * Xdel
            Xmax = Xmax - Shift * Xdel
        Else
            Xmin = Xmin - MoveDist
            Xmax = Xmax - MoveDist
        End If
        '  Set the X-axis extents to these calculated values.
    End If
    '  Recalculate the scaling factors, which might have changed yet again.
    '  If the discrepancy between the scaling factors is less than
    '  say 0.5%, then we can apply the Bobby McFerrin / Meher Baba
    '  algorithm ("Don't worry, be happy").
    '  Otherwise, sigh deeply and begin another iteration.
    Distort = Abs((Xpix - Ypix) / (Xpix + Ypix))
    If Distort < 0.0025 Then GoTo Finish_Off
Next CycleCount
'  Tell the long-suffering user that adequate convergence
'  has not been achieved.  Then carry on regardless.
Distort_pc = Round(100 * Distort, 1)
MsgBox "Discrepancy between scales is " & Distort_pc & "%" & Chr(13) & _
       "after " & MaxCycles & " iterations.", , _
Finish_Off:
End With        'Terminates the "With ActiveChart" near the top of the subroutine.
End Sub
I haven't tried your code out, but I definitely will next time I try to plot vectors.
Thanks for sharing your efforts... including generous commenting within the code which really helps the slower among us like me.
Ain't it always the way? After nearly five years of intermittent tinkering with that subroutine, I finally get around to posting it. Then less than 24 hours later I find another desirable improvement.
The lines
Code:
If Xmax - Xmin + Ymax - Ymin <= 1E-20 Then
    MsgBox "Chart is of zero size.", , PlotName & " / " & SubName
    Exit Sub
End If
should be inserted after the lines
Code:
    MsgBox "Chart contains no points.", , PlotName & " / " & SubName
    Exit Sub
End If
This is not really an error-fix. More a robustness-boost.
Electricpete. Thanks for your kind words. Also for your involvement in the original post. But you misunderstand the reason for the comments in my subroutine. They are there for my benefit, not yours: there is nothing more embarrassing than to return to one's own work after a few months and not understand it.
Is thi ssubroutine applied by assigning a macro to a command button, say? I tried it but got an error. How do you apply this in practice?
Tata
The GiveActivePlotEqualScales subroutine requires that the chart on which it is to work its magic be "active". To use it "manually", make your chart active, then run the subroutine by whatever method suits.
However I usually want it to run under VBA control. To achieve this I use the following subroutine, which attempts a guess as to which chart is to be operated upon, makes it active, then calls GiveActivePlotEqualScales. You might have to make some minor changes to it to get it to suit your circumstances, particularly if your spreadsheet is protected (like mine usually are).
I usually set my spreadsheets up so that MakePlotActive is called from the Worksheet_Change event handler.
The subroutine, like GiveActivePlotEqualScales itself, started life as a Jon Peltier production.
Code:
Sub MakePlotActive()
'  Runs GiveActivePlotEqualScales().
'  First tries to run it on the active chart on the active sheet.
'  If no chart is active and there is exactly one chart on the active sheet
'  it will work on that chart.  If there is more than one chart on the
'  sheet it gives up.
'  The macro also works if the active chart is a chartsheet rather than a chart
'  that is embedded in a worksheet.
Dim OldRow As Long, OldCol As Long, ShtProtected As Boolean
Dim OldCell, OldUpdateState, Targ As String, ChartCount As Long
If ActiveChart Is Nothing Then
    '  Since there is no active chart, we can only know which chart to work on
    '  if there is precisely one chart on the active sheet.
    ChartCount = ActiveSheet.ChartObjects.Count
    If ChartCount < 1 Then
        MsgBox "Active sheet does not contain any charts."
        Exit Sub
    End If
    If ChartCount > 1 Then
        MsgBox "Please select the chart whose scales you want to equalise."
        Exit Sub
    End If
    '  Some preliminaries, for speed and so the screen can be restored correctly.
    OldUpdateState = Application.ScreenUpdating
    Application.ScreenUpdating = False
    OldRow = ActiveWindow.ScrollRow
    OldCol = ActiveWindow.ScrollColumn
    Set OldCell = ActiveCell
    '  If sheet is protected it must be unprotected,
    '  but note hard-wired password.
    ShtProtected = ActiveSheet.ProtectContents
    If ShtProtected Then ActiveSheet.Unprotect Password:="P U T   Y O U R   P / W   H E R E"
    ActiveSheet.ChartObjects(1).Activate
    Call GiveActivePlotEqualScales
    If ShtProtected Then _
        ActiveSheet.Protect DrawingObjects:=True, Contents:=True, Scenarios:=True, _
    '  Clean up with the "postliminaries".
    OldCell.Activate
    ActiveWindow.ScrollRow = OldRow
    ActiveWindow.ScrollColumn = OldCol
    Application.ScreenUpdating = OldUpdateState
Else
End If
End Sub
In my enthusiasm to have this be as general as possible, I have probably made it overly complicated. If you want to err in the other direction, you could probably get away with:
Code:
End Sub
