Direct injection, due to higher pressures and greater efficiency. Diesel has that already, but gasoline/petrol engines can have it too, eg Mistubishi's GDI and Volkswagen's FSI. There is no reason that I see (other than cost and manufacturers sweating their carburtor engine assets) to go halfway and up the compression ratio to the point where the fuel compression ignites (HCCI) without upping the compression ratio further still and injecting it to stop it burning too soon.
I think we will see some form of energy recovery, a bit like KERS being introduced in formula one, but I don't know what form energy recovery will take on the streets.
My understanding of flywheels is that for a street car, a flywheel would have to be on the engine side of the gearbox, whereas for F1 it's being designed to go wheel-side. I estimate it can be used from about 75 MPH to 225 MPH. Below that you might not need it due to wheel spin from eight or nine hundred horsepower. On the street you'd want to use recycled energy at low speeds, eg in start stop traffic - that's very different.
Supercapacitors and electrc motors?
I don't know enough about it. The energy capacity of the top supercapacitors looks good on paper, but whether they can be made at those power densities at a low cost I don't know; I have my doubts.
If you recover energy with an air tank, can engine and exhaust heat be used to increase pressure and thus provide a form of waste heat recovery in a practical manner, and could something like that lie behind Tata's interest in the air car, rather than Tata thinking of the air tank as the prime mover?
Apart from that I just see incremental improvements:- more gears, electronic control of the gearbox being used instead of manual or mechanical control, aggressive shift logic, more use of economy overdrive ratios, dual clutches and similar, battery charging on braking only, engine off when stopped, more diesels, smaller engines, electric oil devices used as much as required where mechanical oil pumps etc follow engine speed, electronically controlled valves, ...
Basically, I envisage energy recovery and incremental improvements. Electronically controlled valves should allow real compression ratios to vary to avoid knock and oxygen sensors should allow AFRs to vary to adapt to different fuels, so I imagine we'll see cars that car run on a variety of fuels.
Even if there is a switch from one fuel (hydrocarbons) to another (hydrocarbon agrifuel mixtures, more carbohydrate), there would logically be a time of mixted fuel availability and so the logical choice of vehicle would be one that can accept multiple fuels, eg gasoline/petrol and ethanol, but once gasoline/petrol is direct injected at pressure where it will autoignite, the real difference between fuels is eroded, just like electronic control erodes the difference between manual and automatic gearboxes.
The Tesla, with its ability to go 200 miles downhill and a its otpional diesel generator to recharge it? Nah, I don't see that as the future. It's a milestone in the history books, marking a change in battery technology, but not much more than that. I do 600 mile journies at times. The solution for that with the Tesla would be to buy the optional diesel recharger and to recharge while driving to reduce stopage time. That would in my opinion make the Tesla a diesel. Yes, you can burn the diesel in a power station, and yes the power station could be coal powered or whatever. That makes the Tesla nevertheless a disel or cola powered car. It could be nuclear. But in my opinion, use the nuclear electricity for houses and take an oil power station out of service and use the oil for cars - it makes more sense than using the oil for homes and electricity for cars.
There will always be some guy living on a hill with a wind turbine or by a river with a waterwheel. I think everything including the Tesla should be developped. I just see those things as niche market rather than mainstream. But as life gets harder with the easy oil disappearing and population increasing, diversification will be more important and there will be more of a market for niche technologies.
The advent of automatic transmissions that will fit small cars will cause a change in American city driving habits. Where small cars were only available as manuals and rejected by the American public in the times of cheap oil, new small car automatics sales will explode in US cities in the years to come when oil starts to become expensive.
In many places a litre of the world's non replaceable oil still costs less than a litre of renewable organic milk. Although I love to quote that one, I think finally fuel here costs more than milk, but it is still an illustrative example.
