grip compile 3
You need to use Grade to compile and link GRIP programs. It should be installed with the NX installation. You used to need a GRIP development license to run GRADE, but they may have removed that since GRIP is no longer supported.
Ben Loosli
We still have a grade license, trying to get them to upgrade to a snap license though. The program linked and compiled fine but I didn't try running it. It should be attached to this post.
NX10.0.0.24 MP1/Windows 7 Service Pack 1
 http://files.engineering.com/getfile.aspx?folder=ffe94320-7cd1-4720-a9e0-63d2ce0a3514&file=move_to_layer.grx
You may get some strange behavior with datum csys features if the user specifies different destination layers for datum planes, datum axes, points, etc. A datum csys feature packages up 3 datum planes, 3 datum axes, a point, and a csys object; generally these are kept together on the same layer. The grip code may separate them out to different layers.
www.nxjournaling.com
yes cowski I am facing some issues with this grip. sketches are not going in the assigned layer. can you help me with this program to move objects in specified layer for e.g. solids=1, sheets=11, points=62, datum csys=61, sketches=21, datum planes=62, curves=41. it will be very helpful as we have parts with very big part history and the layers are not set properly.
Thanks in advance to all of you.
