I am trying to design an exhaust system that would make it very hard for a heat-seeking missile to identify.
I have read that the F-117 stealth fighter uses "heat conducting materials" in its exhaust ducts to take some heat away from the gasses leaving the engine.
I am thinking about surrounding the exhaust with the foam that the space shuttle uses to protect itself from the high temperatures experienced during re-entry to the earth's atmosphere. This material can hold a MASSIVE amount of heat energy.
However, my thermodynamics is a little rusty, since I haven't studied it for a couple of years.
I know that the zeroth law of thermodynamics says if the temperature of two bodies in contact is the same, there is no flow of energy between them.
I know that if the exhaust gas was held in a container, over time it would reduce its temperature until it was equal to the temperature of the ambient atmosphere.
The problem is that the exhaust gas is constantly being renewed, so the temperature of the gas at the point where it leaves the turbine is always the same (about 720 decgrees C). If the space shuttle foam was next to the gas flow, I think it would just heat up until it is also at 720 degrees C, and the exhaust gas would not be able to cool down.
Am I right or wrong?
I would think that two bodies would be in equilibrium when they both have the same internal energy, so if the absorbing material had a low specific heat capacity then it could maintain a higher temperature than the exhaust gas, allowing some reduction in exhaust temperature for a sustained period.
