Heat Sync Question
markdblissmn
14
I am trying to cool a linear electric motor. I want do design a custom water cooled heat sync into the support structure. The linear motor would be bolted to this with thermal paste between. Here is my basic question:
Is it better to have a flow path in one direction across the part? Better to wind back and forth in the same plane? Wind back and forth between different layers of the heat sync? I'd like the temperature of the cooled plate to be as uniform as possible, as the linear motor performance drops due to uneven temperature distribution.
Mark
Mark Bliss
Heat SINK?
Your parallel design provides the most uniformity.
TTFN
faq731-376
7ofakss
But parallel gives the least deltaT temperature increase compared to a longer winding flow path, correct?
Yes, Heat Sink. My apologies!
Mark
Mark Bliss
Mark-
Engineers have a tough enough time combating the popular notion that they are crappy writers. Please check your work before posting it for the world to see!
Tunalover
