Helipads Load 3
SPR Baker
50
Dear all
I have question on design load of Helipads as per ASCE7-16
1.Should we apply load of Helicopter only (1.92kPa/2.87kPa)? and how about effect wind from Helicopter? [Pic-1]
2.Other section 4.11 in ASCE state that 2 kinds of apply concentrated load: 2 single concentrated loads (2.44m) apart with 0.75 takeoff weight on area 200mmx200mm and A single concentrated loads with 13.35kN on area 114mmx114mm.My understanding is corrected?[Pic-2&3]
3.If you have any idea on Helipads, please share me
Big thank you
We’ve done a few helipads. It depends on the type of helicopter. Make sure you consider dynamic loads as required, ie hard landings.
@Tomfh
please share me some document
Big thank you
Thank Tomfh
and can you share experients on System of Supporting Structure we direct using beam column and slab or use Isolation system ?
Thanks Tomfh...
