gmcjetpilot
Aerospace
- May 21, 2007
- 11
NEED IC/circuit compares 2 RF FREQS, one fix and one sweeping. When they are same I want a trigger to send a 5 volt pulse. See picture below.
Is there a IC chip for RF comparison detecting between two signals.
The idea is compare a FIXED RF signal (any where from 455Khz to 12 Mhz at least, more range the better) with a sweeping Frequency (RF signal of fixed voltage). The idea is when they are the same, it triggers a pulse to the Z intensity input of the scope.
Do you have any part and circuit ideas?
Here are the design parameters.
Sweep - Rate about 60 Hz
Sweep of RF freq is constant voltage
Sweep - Width (Frequency) about 300 Khz to 1 Mhz or 3 MHz
Fixed Freq - close to center of Sweep width, symmetrical sweep
Signals are unmodulated & have control of attenuation of both
