MarkJ_
- Jul 8, 2021
- 9
I am trying to perform a simple bending stress calculation on a bolted flange interface but keep calculating a huge bending stress and can’t see where I am going wrong. Please can someone help?
I have a tool that is 2.9 metres long and weighs 250Kg. This has a bolted flange interface at the far end and I want to verify that the bolts can take the weight when I lift the tool from horizontal to vertical from the other end by crane via a lifting point. The bolted flange interface is is 4 x 8mm bolts all spaced equally 80mm apart.
So I am using the basic equation, Stress = (M*y)/I
M = 1778 Nm (I calculated this as being the weight is divided equally between all 4 bolts so 613N per bolt x 2.9m).
y = .004m
I = 2.0106e-10 m^4 calculated using: ((pi*d^4)/64 where d = .008m)
Stress = (1778*.004)/2.0106e-10 = 35372.5 MPa
This is a huge stress and I can’t help thinking I’m going wrong somewhere. Can anyone help?
Mark
y = .004m
Mark
