mabel12
Materials
- Jun 14, 2011
- 3
I have a reactor tube that (during an excursion) saw pressures of about 43.5ksi (300MPa) and reached 2372F (1300C) for approximately 45 seconds (very worst case scenario). The reactor tube is AISI4340 material and approximately 2" thick (2" ID). Reaction was instantly killed after that excursion and temperature and pressure came down to ambient and zero, respectively, in a question of minutes.
I have two questions:
- How deep/ thick into the wall of the tube could have gotten above 727C during that period? (there must be an equation for this?) Assume the reactor tube outside surface is chilled with water at 20C and there is no fouling on the inside of the tube.
- Could the internal pressure on the pipe have any effect on the melting point of the steel?
Thanks!
Thanks!
