History of some of my Excel faux pas (boo-boos) 4
As I recall, it was 6-7 years ago the last time I did something like this. I was actually plotting manufacturing part inventory:
1) on hand (on primary)
2) requirements (negative stacked column chart type on primary y-value axis)
3) replenishment (positive stacked column chart type on primary y-value axis)
4) shortages (negative stacked column chart type on secondary y-value axis)
5) surpluses (positive stacked column chart type in secondary y-value axis)
Skip,
[glasses]Just traded in my OLD subtlety...
for a NUance![tongue]
 http://files.engineering.com/getfile.aspx?folder=782315e1-6127-43f2-9a57-ad1a54064645&file=Chart_Examples.xlsx
Doug,
I did this for a former colleague from Bell Helicopter a couple years as an example of what he could expect. Unfortunately this chart example actually uses a category axis, because I aggregated the chart data point values by week. The axis can be changed to a DATE axis type and the plot is proportionally accurate but not visually impactful.
If you want to check it out, enable macros, select the cell containing RP-RQ Surplus-Shortage Forecast Chart in the Dashboard.
Skip,
 http://files.engineering.com/getfile.aspx?folder=9a76a67c-3e7c-45d9-bee8-1697a37317e2&file=Greg.xlsm
I have found John Walkenbach's Excel Charts book very enlightening for making charts do extraordinary things.
Skip,
