Hole callout on circular surface
Trent5791
108
Hole callout on circular surface does not work. Please help.
Thank you,
Trent
NX 11.0.1.11
Not sure what you mean - is the surface planar but circular in shape? Or is the surface spherical?
And has the hole been created using the hole feature command?
Carl Harrison
That is a known issue.
A workaround is to create a tangent Datum plane first on the cylindrical surface. Use that to place the hole feature.
Then your callout will work. I believe it has been fixed in NX12
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
The datum plane workaround did not work. So LAME that it took them 12 versions to fix a "known issue". I guess I can say, I'm looking forward to NX 12 as we are still using 11.
Thank you,
Trent
NX 11.0.1.11
On NX11.0.2 it is working, but only for Linear dimensions.
The radial dimension doesn't work.
The hole Callout hasn't been there that long. I think it started in NX10?
NX9 / TC10.1.2
