sedonas
- Oct 16, 2015
- 82
I have unsuccessfully applied non-shrink grout to a 10mm gap under the base plate. We put water on the pail and put the grout.. we stirred them until they were flowable consistency.. then we poured it on the form works inlet (with outlets for air to go out) around the base plate. As we poured it.. the heavy part very quickly settled and only the very liquid part was on top of the pail. The next day when I removed the form works.. there are voids and it was so soft that we were able to remove it by bar.
Did you use electric stirrer to mix it or by hand.. when you first tried it.. were you successful? What technique did you use?
