Ozy001
- Sep 19, 2011
- 13
How do you calculate the force in a compression flange based on the moment?
I am trying to calculate how much force is in the compression flange of a portal column based on its moment. I have to design a torsional restraint (capable of withstanding 2.5% of the force of the compression flange). The angle of the tie from the compression flange to the restraining member is very accute and as such I am a little worried about the steel angles which have been added. Was thinking it would go something like this:
Calculate the Z vale of the compression flange only.
Divide the moment by the Z value to get a stress.
Multiply the cross sectional area by the stress. That should give me a maximum applied force.
Find the resultant force based on the angle of the tie.
Check the angle against the maximum force in compression to see if it passes.
Any help would be really appreciated.
Thanks!!!
Thanks!!!
