For everyone of my projects I prepare a three ring binder (I may have multi volumes depending on the project size). Here is how I divide up my calculations:
1. Code search and brief narrative as to the codes used, assumptions, and construction material types to be used.
2. Loads (dead, live, wind, snow, seismic, etc). I usually make copies of relevant code tables and material data that will be used for the project. I also compute wind pressures for MWFRS and C&C. FBC requires C&C pressures, amongst other data, be placed on the drawings.
3. roof framing members to include deck, joist, beams and girders. This will include FBED, computer input and output regardless of which software I use. I learned that hard drives will crash and without hard copies you will be SOL. I always list name of software used.
4. Floor framing members to include deck, joist, beams and girders. This will include FBED, computer input and output regardless of which software I use. I learned that hard drives will crash and without hard copies you will be SOL. I always list name of software used.
5. Column section to include load tabulation and sizing. Hand calculations and computer output is included.
6. Foundation section that will include:
a. Geotechnical report
b. Summary of foundation loads
c. Any relevant sketches
d. Foundation design to include hand and computer output of calculations.
e. Footing schedule
f. Relevant sections and details.
7. Wall Section to include:
a. Wall loads
i. Vertical dead and live loads.
ii. in plane lateral loads
iii. Out of plane lateral loads
b. Wall design calculations.
c. relevant sections, details and connections.
8. Drawings. I usually place a permit set (11X17) with the calculations.
9. Correspondence section. This section usually has the following:
a. Statement of work from client
b. meeting minutes
c. e-mails from clients including architects, owners, vendors and fellow engineers (MEP)
d. written phone messages
e. Pictures of field conditions
f. any relevant misc. item that I deem important.
I may be missing few items since I am writing from memory at home.
Lutfi
