How to Calculate Blind Flange Thickness With Opening 1
mechyp
30
Dear All
any clause for Calculating Blind Flange Thickness with opening grater than 1/half of flange OD(flat head
this Bolting joint as per UG-34(j)
Blind flange 20" (As Per B16.5)
Nozzle OD 438
Thickness 37 Thk min
as per UG-39(C)(1) i have to go Appendix 14 but scope of Appendix-14 is
The shell-to-flat head
Joint shall be either integral, as shown in Fig. UG-34
sketches (a), (b-1), (b-2), (d), and (g), or a butt weld, or a
full penetration corner weld .
my joint configuration as per UG-34(J)
Hold the BC and OD of the flange along with gasket surface and adjust the ID of flange calculation in App. 2 accordingly to match your requirements.
