Goleon
- Jul 7, 2020
- 8
Hello everyone,
i'm working on a simulation where i have two parts, one solid deformable and one rigid shell. I tried to connect the solid part to the shell and then deform the solid part by rotating the rigid part. First i solved it within an implicid step and used a tie constraint, where i tied two surfaces to each other. Now i want to do the same simulation as an explicit simulation but i get an error that i can't use a tie constraint. I tried many different ways but can't get the simulation running. Has anyone an idea how i can connect the solid part to the motion of the shell part?
I'm using Abaqus CAE 2019
