How to delete a perimeter dimension
ChrisDyson
Industrial
Aug 7, 2013
6
Hi Guys,
I've opened up a sketch with a perimeter dimension, but am unable to delete it.
I've tried Tools > expressions > then found the value in the list, highlighted it but the delete button (X) is shaded out.
Any ideas where I'm going wrong?
Chris
Try and delete this perimeter dimension from the sketch environment.
[ul]
[li]Go in this sketch (edit with rollback or edit)[/li]
[li]Click on any dimension command, like Inferred Dimension[/li]
[li]Toolbar Dimensions will show up. It has tree icons[/li]
[li]Click on the firs icon, Sketch Dimensions Dialog[/li]
[li]In this dialogbox, from the list of sketch dimensions, select the Permiter dimension you want to delete[/li]
[li]Now, click the Delete in this dialogbox and Perimeter dimension will be deleted.[/li]
[/ul]
