Hi All,
I'm trying to model a magnetic interaction between a shaft an the stator. The magnetic interaction behaves like a spring with negative stiffness: When the shaft approaches the stator, the attraction force increments.
I've tried using a connector element with negative stiffness, but Abaqus gives a error "ELASTIC STIFFNESS MUST BE POSITIVE".
The step is "Steady-state dynamics, Direct"
anyone knows how can I model this interaction?
Thank you in advance
