I cannot bring up alternatives to CO2 without being mobbed.
Skogsgurra
SE
PC has now taken over all discussions on climate and reasons for climate changes.
I try to keep an open mind, but Sweden has always been a consensus society and consensus is now total. Any other possible mechanism than CO2 is now banned and not allowed to be brought up in discussions.
What do you think about such a society?
Gunnar Englund
Not there?
OK - there was an umlaut in the filename. Changed to 'aa'.
Gunnar Englund
Is that backhoe in the picture digging an ozon hole?
The ozone hole pretty much repaired itself within 10 years of most countries ceasing production.
Pat
See FAQ731-376 for tips on use of eng-tips by professional engineers &
for site rules
Interesting that few people dispute that we created the ozone hole with only about 100 years of using chlorofluorocarbons, and that stopping production and usage repaired same hole.
TTFN
FAQ731-376
Chinese prisoner wins Nobel Peace Prize
Yes. That is interesting in many ways.
When the alarm went off, we heard that it was too lat to do anything and that the damage was irrepairable. I even think that the Precautionary Principle was born as a result of that hole.
But it differs from the climate change a lot. There was a clear mechanism and not many other explanations.
Gunnar Englund
Nonetheless, it was an anthrogenic climatic change, with much less total stimulus than greenhouse gases. If you agree to that premise, then anthrogenic global warming is well within possibility. The fact that we don't completely understand the mechanisms doesn't mean it doesn't work. We built transistor radios for decades before a "complete" model of the transistor was developed.
TTFN
FAQ731-376
I do not think that your parallels hold for a deeper scrutiny, IR. You bring in so many loosely connected subjects and ungrounded assumptions in your arguments that I really cannot say anything about them.
Gunnar Englund
I read an article on the ozone hole a few years ago. The author claimed that since CFC's are significantly heavier than air, their ability to reach the ozone layer is pretty limited (his theses was that they would react with other stuff long before they got that high). He pointed to atmospheric samples that contained zero CFC's long before they were banned. His point was that the experiment that doomed the best refrigerant ever devised was to pump outrageous concentrations of CFCs into a closed container of ozone. It reacted (of course ozone is one of the most reactive chemicals on the planet), so ergo, ipso facto, CFC's are eating the ozone layer AND WE'RE ALL GOING TO DIE. No relevant cause and effect data whatsoever. I tried to find the article, but was unsuccessful.
Ditto the uproar over DDT. Ditto the uproar over the Corvair (Nader admitted that the data in his "Unsafe at any speed" article was fabricated). And I have to say ditto the uproar over Anthropogenic Global Warming.
Man can and does do bad local stuff. Breathing in the LA Basin or Shanghai or Mumbai is hard on your body. Drinking water from the East River in New York or Nile Delta should probably be avoided. These are local effects. The earth is a pretty big place and has had millions of years to evolve processes and organisms to clean up messes (I don't see any ash from Vesuvius hanging around in the air, or much oil on the surface of the ocean from the thousands of natural blowouts that are leaking at any given minute). None of the things we do is nearly big enough to present a hazard to the globe over geologic time.
David
Over geologic time, probably not, over a few human life times though?
Posting guidelines faq731-376 (probably not aimed specifically at you)
What is Engineering anyway: faq1088-1484
Haven't you heard? The ozone holes were caused by HAARP! ;-)
"Good to know you got shoes to wear when you find the floor." - [small]Robert Hunter[/small]
Yes, you're right..
