Franc_DL
Industrial
- Mar 22, 2019
- 3
Hi all,
I need help to how calculate vent size\ air flow rate to venting of insulated tank for vacuum relief by a CIP process.
Process:
spray ball water injects inside tank with hot water to 95C degr - flow rate 18 m3/h pressure 2 bar
Then, in second order, spray ball with cold water to 9C degr flow rate 18 m3/h pressure 2 bar
The problem is the colapse of the tank produced by the vacuum for this process.
The max. allowable vacuum pressure is 6,3 mbar and the design pressure 5 mbar.
Thanks in advance,
Process:
Thanks in advance,
