Quite often I import Autocad DXF sheetmetal flat patterns, which include bend lines. I then convert the bend lines, in the sketch, to reference lines. I then extrude and convert to sheetmetal. Now I want to use those reference lines as bend lines, but "add bend" will not allow me to select reference lines as a bend curve, and if I try projecting sketch to a new sketch to derive the bend lines, NX only projects non-reference sketch entities. What method would not force me to re-sketch the bend lines manually?
NX 8.0.3.4
NX 8.0.3.4
