bthomasxxxyyyzzz
- Oct 11, 2021
- 1
Hi all, hope you are all well. First time posting here, so please excuse any mistakes I've made.
I'm on a project where we're designing a rainwater storage and pumping system that ties into the overall processing plant. In one area, we have a sump pump which discharges into a storage tank, and the discharge from this tank ties into the process plant. The sump pump is in a vehicular traffic area and the client wants any potential diesel / hydrocarbons in the rainwater going through the sump pump to be filtered out prior to the water going into the tank, and then into the downstream process.
I've been searching for in-line filters, diesel filters, oil separators etc. and the majority of what I'm seeing seems to be stand-alone skid-mounted equipment. We're hoping to source something that is more "in-line", similar in concept to a Y-strainer or basket strainer, that could be supported on a small frame if need be. We're trying to stay away from skid-mounted equipment if possible.
I've attached a screenshot of the area I'm talking about.
Max duty for the sump pump has been specified as 46m3/h and 7.6m head, so we're looking for a filter that can perform at this duty as a minimum.
I'm hoping someone might have come across something similar to what I'm talking about and can point me in the right direction, please.
Thanks for your time.
Brett.
Brett.
