Integrate ampere measurement over time? 2
SolarTrap
Computer
May 5, 2014
89
I am looking for an I2C device that can help with accurate measurement of amps (+/- 50A @30VDC) flowing in 2 directions (in and out of batteries). I am currently using an Arduino to do this but accuracy is low in terms of available bits at the ADC but especially with the sampling rate I am able to do the measurements (10Hz) with. Is there a chip that is able to integrate the amps over time until I read it?
Markus
"in a very dynamic load pattern I might miss a few peaks." - Add an analog peak detector circuit. Or if you can sample the A/D faster in your interrupt service routine you can implement a digital peak detector.
Z
You'll have to provide a power supply for it (it draws very little current, 100 uA or so, 1.5 uA in shutdown). Since you've got a battery, you could probably power it by 2 or 3 cells closest to ground with no ill effect and put the shunt in series with that and the more positive cells, something like this:
[gnd]--[2 or 3 cells]-+-[Rshunt]-+-[cell]--[cell]-- ... --[Batt+]
The current range is set by the shunt resistor. +/-50 amps full scale would be 1 milliOhm. Plenty of options there:
I did something similar for a 15 Amp-Hour 48 volt battery pack.
Hmmm...all this is way out of my league; no matter what type of uC I was looking @, I don't think I would recognize 1 were I2C1... [bigsmile]
CR
CR, are you not fluent in over 6,000,000 forms of communication?
Z
Hey zappedagain, actually, I don't believe I am...
CR
