Intelligent pigging - minimum velocity?
London
42
Hi
I am doing a study on intelligent pigging. We are laying a new 22" pipeline and tying into an existing line with a Wye piece.
I line will need pigging to determine corrosion loss during its life
Towards the end of field life, velocities of oil are going to be very low (0.1 m/s or less)
Is there a minimum velocity that an intelligent (MFL) pig can run?
Bad news. Don't worry about the pig, the minimum velocity for oil lines is 10 x faster than that.
"Pumping accounts for 20% of the world’s energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies)
The minimum velocity required for pigging is 0.5m/s, the optimal for MFL tools is 0.5~1m/s for liquid pipelines and 3~8m/s for gas pipeline.
For liquid line, to achieve high pressure/velocity you could use water [off course treated and inhibited] with additional pump.
The IP vendors data sheets will provide the tool specific pressure/velocities.
Narendranath R
Pipeline engineering is made easy with state of the art computer software, visit
thanks narenr
this is the information I have also. the reason why I ask the question is because I believe the minimum speed is not due to the Magnetic Flux Leakage energising the line, but rather the odeometer on the pig itself.
I have spoken to one vendor and they have said that MFL is good for 0-5m/s.
now all I need is someone to back that information up
The induction coil on the tool may require a minimum speed to measure the rate of change of flux density. Slow is good; but not too slow! NACE RP0102 and API Std 1163 will guide you in what to go through with service providers in order to confirm pig performance capabilities.
Steve Jones
Materials & Corrosion Engineer
Thanks Steve, I will check that out.
London
Slow speed is not a concern with the newer Hall Effect Tools, it's battery life that would be a problem for extreemly long duration runs. There are ways to extend battery life if necessary.
William
William G. Callahan P.Eng.
Pipeline Management Group
Baker Hughes
