Is it worth to start from zero to learn Rhinos just to export a model to Sap2000
juandavidguzman
11
I have to calculate and design the reinforcement of a concrete shell structure like this one:
So i was advice to use Rhinos for making a mesh surface and then analyze it in Sap2000 (even though i do prefer Staad.Pro i can get my hands to work on Sap2000).
I'm worried to get into a rabbit hole just to make this surface and i don't have too much time to waste for this project.
what do you think? is it worth to model the structure in Rhinos and then analyze it in Sap2000 or Staad?
Is this structure really going to have a lot of two-way bending? It's tough to tell from the picture.
It looks like you MIGHT be able to get away with modeling a 1 ft strip (using beam elements). Even if you do have some two way bending, you can "envelope" the main direction bending with a series of 1 ft strip models. Then add in Temp / Shrinkage in the other direction with maybe a little extra to account for any secondary direction bending you might have.
