Is this sketchy?
XR250
5,921
Just walked by this in downtown Burlington VT. Wow!
Probably been like it for 50 years. So sketchy yes, but proven to work?
ok, so it hasn't fallen down ... yet.
And maybe care was taken to align the diagonal supports with interior walls and not just on the face of the exterior walls (yeah, right !).
and look how well cared for it is.
if you have to ask, then it is "sketchy". is it "Bad" ? well, see first comment !
That is a classic WAC support. We use them all the time for a Window Air Conditioner. Works for the loads it has been exposed to but probably would fail if loaded with the building code required loadings.
Don't worry if it falls with someone on it. The electricity below at that bank of meters will cauterize any wound you get. Instant first aid.
Well, since we're doing this...I see your sketchy stair and I raise you a miracle column (or is it 2 columns?):
Pesky mezzanines.
Looks like it already has some P-delta going on....
There definitely used to be a mezzanine, that was removed. "oh just cut it flush to face of column, it'll be fine."
Yeah it was a mezzanine in a massive department store (~250k SF) in Los Angeles which had been demised into ~6 retail units/strip mall. The mezz covered a good 50% of the entire building. So over the years each tenant slowly hacked away at the mezzanine in their spaces. Our client's space had the only remaining piece of mezzanine and wanted to remove it (or...part of it) so I was walking around in the other stores to see what was left of it and found this gem. The tenant didn't seem to understand what the problem was. Hopefully the building official helped them see the light. What a nightmare project.
And yes, P-delta for sure. Or is it...Pre-delta?!
Regarding the stairs, there is simply no redundancy in the failure mechanisms. It's all or nothing on the way up. Tread bravely.
I did a report for a balcony collapse in Peterborough, Ont about a decade back, and people were injured. Construction was similar with diagonal struts bracing back to the wall at the bottom (struts were longer and attached near grade, but the same thing). Failure occurred because of 'dryrot' damage to the attachment material and let go. There were several people on the balcony but still below code loading. The real problem was that when failure initiated the force on the fasteners was increased due to the rotation, and collapse was catastropic.
I sent a pic of it to the building official. I hope they act on it.
from the O'Reilly School of Interior "Structures" or "building things just waiting to fall down"
Private entrance for an attic apartment? I'd be surprised if the only sketchy thing is the stairs.
XR250,
What is on the other side of that exterior panelling?
JHG
Looks grim, fire escapes are very difficult to engineer and these folks weren’t even close.
What's the problem? The top landing is sitting on cantilevered beams, so you have that entire, probably illegal, penthouse counterbalancing the landing. Besides, I'm sure they lagged the supports into the studs in the wall.
The columns supporting the stairs, on the other hand...
TTFN (ta ta for now)
Dunno for sure. I imagine wood studs. This is not a job of mine - passed on my way to get coffee.
You know, based on alignment with the windows and the roof vestibule (pardon my lack of architectural vocubulary) above...
Part of me thinks there is a chance the brace is actually aligned with a stair landing. In which case... I'd be inclined to say it not only works, it probably calcs out too.
Of course, that's a guess from just the one picture.
just call me Lo.
