shvet
Petroleum
- Aug 14, 2015
- 744
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
This is not going to work; you will carry forward light phase with heavy phase.
You must disconnect the light phase pipe.
Pierre
Not when there is no inflow it isn't.Little inch,
it is very clear ! this is a LL separator.
bottom valve is closed , open only to drain the separator.
Green is light phase , red is heavy phase .
The interface is controlled by the height of the inverse U pipe .
Pierre
Shvet.
Block the light line, no connection to the vapor space.
A description and explanation are given in Perry's chemical Engineer's handbook - page 15-26 -7th edition
A schematic with equation.
In your case ZL is the height of the weir .
What is the L-L coalescer used in the 2nd diagram - a knit wire mesh pad or a tilted cross flow plate pack or some other?
