Link Between Abaqus Documentation and the Software
CrazyMan
4
Hi everybody!
I am glad to join your group, and I hope learn new things from the members here. I use Abaqus v6.9.3, and after installation, I couldn't directly access the documentation through the provided link in help menu, and I think the provided address was incorrect while installing. Now I want to know is there any way to link between them manually . I think it can be done using Abaqus Command, but I am not sure. Please help me with this. Thank you in advance.
Thank you loki for your response. You're right, but whenever I type it into my browsers' address bar, it does not show the page. It gives the message "Unable to connect" whether I would be online or offline. How can I fix it? How can I make the connections between them? There are source files installed in my PC's drive.
go to control panel, admin tools, services and look if the abaque web server (might be different name) is actually running.
Thank you loki. It was running. I solved the problem! The problem was due to installing product before documentation. Thank you anyway for your comments. They were helpful.
