Video of the collapse due to high river:
Before:
After:
faq731-376
Before:
After:
faq731-376
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
msquared48 said:100 year storms now are not what they were 83 years ago... Computer models are always changing as more data enters the system.
A NOAA analysis released today finds significantly higher rainfall frequency values in parts of Texas, redefining the amount of rainfall it takes to qualify as a 100-year or 1000-year event.
The study, published as NOAA Atlas 14, Volume 11 Precipitation-Frequency Atlas of the United States, Texas, found increased values in parts of Texas, including larger cities such as Austin and Houston, that will result in changes to the rainfall amounts that define 100-year events, which are those that on average occur every 100 years or have a one percent chance of happening in any given year. In Austin, for example, 100-year rainfall amounts for 24 hours increased as much as three inches up to 13 inches. 100-year estimates around Houston increased from 13 inches to 18 inches and values previously classified as 100-year events are now much more frequent 25-year events.
NOAA Atlas 14 rainfall values are used for infrastructure design and planning activities under federal, state and local regulations. They also help delineate flood risks, manage development in floodplains for FEMA’s National Flood Insurance Program and are used to monitor precipitation observations and forecasts that can indicate flooding threats by NOAA’s National Weather Service.
38 Robinson City Park in Llano will flood. Many homes in Scotts Acres on south side of Llano will be severely damaged and lowest mobile homes destroyed in water up to 6 feet, some washing downstream. Many homes near Castell to below Llano will be damaged. The FM 2900 bridge in Kingsland will flood. Much of Kingsland Lodge in Kingsland will be destroyed. Many homes downstream in Marble Falls will flood as flow backs up Backbone Creek.
36 Disastrous life threatening flooding will damage numerous homes and businesses above Castell to Lake LBJ. Numerous resorts at and below Kingsland near the Llano River mouth will flood severely. Boats, docks and any gear that isn't removed from the river will be destroyed. Lower homes on Lake Travis flood severely. Flow exceeds the USGS 1:50 year flood level.
32 Disastrous flooding well into the flood plain will cut off and potentially drown thousands of livestock. Homes, resorts, commercial buildings, boats, docks and marinas will flood disastrously above Castell to Marble Falls on Lake LBJ. Roads and bridges near the river will be severely flooded and dangerous to motorists. Exceeds the USGS 1:25 year flood.
30 Disastrous flooding will reach lowest residences below Castell to below Llano. Flow will be to the slab of the city of Llano water treatment plant on the right bank just above Highway 16. Numerous resorts at Kingsland and in Lake LBJ will have severe flood damage. Boats, docks and facilities lining the lower Llano and Lake LBJ near Kingsland may be severely damaged or destroyed.
26 Major flooding will threaten lowest homes from upstream near Castell to below Llano. Major damage will occur downsteam in Kingsland to boats and docks. Secondary and primary roads and bridges in the flood plain will be extremely dangerous to motorists. Lowest homes and businesses in the Highland Lakes below Kingsland will be flooded.
23 Major lowland flooding makes primary and secondary roads and low bridges near the river and tributaries dangerous. Boats and docks are severely inundated downstream near and in Kingsland. Lowest resorts near the Llano River mouth in Kingsland flood.
20 Flow will be damaging to docks and boats downstream in Kingsland. The lowest secondary roads and bridges will be severely flooded and dangerous. Near the USGS 1:5 year flood level.
16 Moderate lowland flooding threatens docks and boats in the flood plain downstream in Kingsland. Secondary roads and bridges will be flooded and dangerous to motorists. Flow exceeds the USGS 1:2 year flood level.
12 Moderate lowland flooding makes secondary roads and low bridges in the flood plain dangerous to motorists. Equipment should be moved from low docks and boat ties loosened downstream in Kingsland.
10 Minor lowland flooding can swamp boats in the lower Llano River in Kingsland.
Historic Crests
(1) 41.50 ft on 06/14/1935
(2) 39.10 ft on 06/23/1997
(3) 32.60 ft on 09/10/1952
(4) 28.65 ft on 11/04/2000
(5) 22.07 ft on 11/17/2004
(6) 20.51 ft on 02/04/1992
(7) 20.50 ft on 06/27/2007
(8) 12.63 ft on 06/01/2016
(9) 12.13 ft on 05/29/2015
(10) 11.24 ft on 07/06/2002
It's seems like there is ample evidence that extreme precipitation events are on the increase. Not limited to the specific statistical analysis that's relevant in this case which shows: In Austin, for example, 100-year rainfall amounts for 24 hours increased as much as three inches up to 13 inches. 100-year estimates around Houston increased from 13 inches to 18 inches and values previously classified as 100-year events are now much more frequent 25-year events.HotRod10 said:"This type of storm, and the hurricanes, continue to get more frequent and more severe."
Yeah, I heard the same fear-mongering from the IPCC, too. The problem is that the evidence doesn't actually support that assumption.
Perhaps previous estimates were in error? Please consider this is a question, not a statement.Spartan5 said:100-year estimates around Houston increased from 13 inches to 18 inches and values previously classified as 100-year events are now much more frequent 25-year events.
HotRod10 said:So, perhaps the rainfall patterns in Texas are changing. If they are, what does it mean?
Sez who?HotRod10 said:To set the criteria for what constitutes a 100-year (or even 25-year) event with any accuracy, you need far more 100 or even 200 years worth of data.
At first you claimed that talk of changes in extreme precipitation events was fear-mongering not supported by evidence. Then you wavered and said well maybe it's just Texas. Finally there was the hard pivot to "Things change. Things have always changed. There is evidence things have changed as far back as you can go. There is constant change." But I'm the one that has bought into something?HotRod10 said:Technically, it's a statistical anomoly, but you can buy into the junk science if you choose.
A 100 year event, by definition, indicates probability to occur in any given location during a 100 year span. Many 100 year events should be expected to occur in various locations during a 100 year span. Since this storm didn't hit Louisiana, and one might hit there next week does not qualify to assert that two 100 year floods within 2 weeks occurred.HotRod10 said:Also, statistically speaking, 2 or even 3 "100-year events" can happen within a few years of each other; that doesn't suddenly make them 5-year events.
