Lms Virtual-lab. Help!!
glad221
Automotive
Jan 18, 2010
5
I've been working recently with Lms Virtual-lab structure and have the following problem: I want to define a perpendicular force of all nodes in the inner surface of a hollow cylinder.
The force must be perpendicular to all nodes!
How can i make that?
thanks
glad
A node is a 3 dimensional point in space. There is no such thing as a perpendicular to it, or if you prefer, all vectors are perpendicular to it.
Perhaps that is the cause of your problem.
Cheers
Greg Locock
I rarely exceed 1.79 x 10^12 furlongs per fortnight
hello Greg
Thank you for your quick response.
I actually was referring to the elements not the nodes! was an error
I have a picture of the cylinder, the force must be defined everywhere perpendicular to the inner surface (red area in picture)
i dont now how i make that in Virtual-lab!!
 http://files.engineering.com/getfile.aspx?folder=42337fc8-4772-4b65-a3f7-5c9b346af4e4&file=Cylinder.JPG
GLAD221:
You have the dimensions of the cylinder therefore you can write the equation of the cylinder and get the slope equation (dy/dx)....The perpendicular slope is then just the inverse of the slope of the cylinder.....
No idea how to do it in the software....
Ed.R.
