Log Log Excel charts
Tomei
3
Is it possible to have excel insert a chart that has BOTH the X axis AND the Y axis in log form?
Joe Tomei
Sure, are you having a problem with that? You'd need to select the scatter plot for the graph format. TTFN
Yes I'm having trouble.
I can get a log y axis vs linear x axis but can't seem to get Log y & Log x.
How is that done?
Joe
You need to select the x-y scatterplot.
You probably selected the line chart. The line chart only has a category x-axis, not a numerical x-axis. TTFN
Transform your formula to logY=MlogX+logB then you can use the line chart method [smile]
No you can't.
Do it and you'll find out why it doesn't work for XY data. Cheers
Greg Locock
Who can't? Plotting with the XY scatter will allow for X and Y log scale.
You can't use a line chart as Rjeffery suggested, unless your data is already at logarithmcially equal intervals.
Cheers
Greg Locock
Gemtlemen,
Thanks.
I finally understand that the xy chart is fundamentally different from the line chart.
I tried the xy scatter chart, and there, it was duck soup.
Thanks for your help.
Joe Tomei
