  • Congratulations IFRs on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Manufacturing
sketchman
I needed a post processor NX6 with a command machine fagor 8050 with 3 axis, how can I fix this? Thanks
Have you looked at the library of posts available from Siemens?
You could build one with Post Builder.
You can pay Siemens or someone else to make one for you.
Most companies have a lot of $$ invested in Post Processors and are not willing or able to part with them for free.
If you have a sample program, it is not so complicated. You should take a try..
kukelyk
Do you have an example of the code you need? What is the control?
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6 & NX7.5
thank´s
I usually use the post processor ISO but I have to change the header, because the command machine is Fagor,is not very practical.
where i can the construtor post ?
