Mask triples NX10
niedzviedz
307
I have question about mask triples in NX 10. Did something changes in this dialog , because I have journal to select face and change it color. In NX 8.5 it works perfect - select only face, but in NX 10 it also selecting solid body.
Below is my code:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module changeColorOfPreSelectedFaces_v2
    Dim theSession As Session = Session.GetSession()
    Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager
    Sub Main()
        '' Integer variable to store color code in.
        Dim newColorCode As Integer = 114
        newColorCode = Convert.ToInt32(6)
        '' The selectFaces method takes an NXobject array by reference
        Dim selectedObjectsArray() As NXObject
        SelectFaces(selectedObjectsArray)
        '' Need to recast the face NXObjects to Displayable objects
        Dim faceArray(selectedObjectsArray.Length - 1) As DisplayableObject
        For i As Integer = 0 To selectedObjectsArray.Length - 1
            faceArray(i) = CType(selectedObjectsArray(i), DisplayableObject)
        Next
        '' A display modification object is used to change to color of the faces.
        Dim changeFaceColor As DisplayModification = theSession.DisplayManager.NewDisplayModification()
        With changeFaceColor
            .ApplyToAllFaces = False
            .NewColor = newColorCode
            .Apply(faceArray)
            .Dispose()
        End With
    End Sub
    '' The following routine is from GTAC
    '   sub to select faces
    Sub SelectFaces(ByRef selectedObjects As NXObject())
        Dim ui As UI = NXOpen.UI.GetUI
        Dim message As String = "Select Faces"
        Dim title As String = "Selection"
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
        Dim keepHighlighted As Boolean = False
        Dim includeFeatures As Boolean = False
        Dim response As Selection.Response
        Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim selectionMask_array(1) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_solid_type
            .Subtype = 0
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_FACE
        End With
        response = ui.SelectionManager.SelectObjects(message, title, scope, _
                                         selectionAction, includeFeatures, _
                                     keepHighlighted, selectionMask_array, _
                                                      selectedObjects)
        If response = Selection.Response.Cancel Or response = Selection.Response.Back Then
            Return
        End If
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY
    End Function
End Module
With best regards
Michael
Check the NX 10 release notes; sometimes changes to the API are noted. If you can't find anything there, I'd suggest contacting GTAC with this. They are the only ones that can give a definitive answer on what changed and why.
www.nxjournaling.com
Thanks @Cowski, I will contact them. Maybe there is a bug in NX 10. I also noticed, that when I process whole assembly with journal to set some properties and I save and close it, after reload It to new session of NX they are gone, even if I force in journal to save every part after modification. But if I open some parts in new window and then save, they appear after reload. Similar problem I have encounter in NX 9. Can You check by Yourself, if this problem also appears on Your machine?
With best regards
Michael
Maybe try to force a subtype like this :
.Subtype = UFConstants.UF_solid_face_subtype
Thanks for help, but it didn't work. I have create thread about this issue at our support. Probably on Monday/Tuesday I will receive some information.
With best regards
Michael
Hello everyone,
I have some info about this problem. Like I said, I contacted our NX support, and they help me solve the problem. There is an error in my code.
there is:
Code:
        Dim selectionMask_array[COLOR=#CC0000](1)[/color] As Selection.MaskTriple
But should be:
Code:
        Dim selectionMask_array[COLOR=#CC0000](0)[/color]As Selection.MaskTriple
The best thing is that, this is working fine in NX 8,5, I don't know how it's works in 9, but in 10 the problem appears.
One more questions about mask triple. I have this code for change body translucency. I use two selectionMask_array. Can I merge them somehow?
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
    Sub Main()
        Selectbody(selectedObjectsArray)
        Next
        Dim changeBodytransluency As DisplayModification = theSession.DisplayManager.NewDisplayModification()
        With changeBodytransluency
            .ApplyToAllFaces = true
        '    .NewColor = newColorCode
            .NewTranslucency = 40
            .Apply(faceArray)
            .Dispose()
        End With
    End Sub
    Sub Selectbody(ByRef selectedObjects As NXObject())
        Dim message As String = "Select body"
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
            .Type = UFConstants.UF_component_type
            .Subtype = UFConstants.UF_component_subtype
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
        End With
        With selectionMask_array(1)
            .Subtype = 0
	End with
                                                      selectedObjects)
            Return
        End If
    End Sub
    End Function
End Module
With best regards
Michael
