Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
JLNJ said:...Also very important (maybe MOST important in our profession) is how to put together a good, complete set of construction documents. If you can’t effectively communicate the Owner’s needs and the design via the written word and the requisite plans and details, if you can’t write a tight spec, and if you can’t foresee problems and work with contractors, your usefulness in a consulting firm is limited, no matter how many degrees you have.
I’m sure you don’t learn that in school.
Logan82 said:...Which is best for engineering firms, a master's degree with or without thesis?
Are master's degrees in structural engineering useful in engineering firms?
