Maximum Gap for a Pipe Guide Support
Suresh VK
1
Hi all,
Im performing stress analysis for a piping system as per ASME B31.3..
Line Size : 48" NPS
Service : Process Gas
Design Temp : 93°C
Design Pressure : 4700 Kpa
My question is, what is the maximum gap i can provide for the Pipe Guides?
Is the pipe on some kind of "Shoe"? If so please show us a picture or drawing.
Show us a picture or a drawing of the Guide you plan to use.
Sometimes its possible to do all the right things and still get bad results
Do you intend this "pipe guide" to PREVENT motion of the pipe side-to-side or vertical, or do you intend the pipe guide to permit only axial movement, and not to restrict perpendicular right-left or vertical movement?
The width of the guide can be an issue for 'locking action'.
Dik
What sort of gap?
Horizontal? Vertical?
Depends what you're trying to prevent with the guide?
I've seen anything from 10mm to 50mm.
That's design for you.
You should be using Caesar II or a similar software to perform your stress analysis. The software will dictate what gap size will be required. Mainly it depends on geometry, design temperature and, if applicable, wind loading.
Isn't pipe support spacing one of the outputs of a pipe stress analysis?
So far, I have interpreted gap as the distance between a support and it's supporting structure (e.g. the situation you get with support lift-off). I havent considered gap as the distance between 2 supports.
If the OP doesnt return, not sure if well find out what he's looking for.
At least in Caesar II, the pipe support spacing (and support gap) is user defined. For guided shoes with a gap, it depends on the application but could be 1/16" or 1/8". If you mean pipe support spacing, that's a different matter.
