Mexico City subway overpass collapses, killing at least 23 and injuring dozens 2
There is a cross over from one track to the other.
LittleInch,
The truss you refer to is called a cross-fame, used for lateral stability during construction and to account for lateral load transfer such as wind between the girders. Also, if the top flange was unbraced (non-composite), it would provide top flange bracing in the final condition. It does not look like that was the intent though. I noticed it earlier too, it is puny in my experience, especially for a light rail bridge. It does give the appearance that it is buckling.
IC
==> Follow-up 06/13/2021:
NY Times is reporting the following, that the steel studs that make the steel beams & concrete slab composite were poorly welded:
Link
