mil spec ???? 1
PROEGUY
24
does anyone out there know what the MIL-SPEC is for a thru wall mil spec connector spacing arrangement? i believe there is a spec that calls out the distance btwn connectors (relative to their size) in regards to being able to get a persons hand (gloved/not gloved) into an area to disconnect it. i found a spec related to knob spacing but i haven't found anything on a connector spec. thanks in advance for the help
Sr. Pro/E Mechnaical Designer
I don't think it's necessarily the right one but have you looked at MilStd 38999C?
KENAT,
Have you reminded yourself of faq731-376 recently, or taken a look at posting policies: What is Engineering anyway: faq1088-1484
PROEGUY,
Search the internet for MIL-STD-1472. I have version F here, and I just searched for "connectors".
MIL-STD-1472F said:
5.9.14.7 Spacing. Connectors shall be spaced far enough apart so that they can be grasped firmly for connecting and disconnecting. Space between adjacent connectors, or between a connector and any adjacent obstructions, shall be compatible with the size and shape of the plugs, and the type of clothing worn by the maintainer (e.g., cold weather handwear, NBC gloves). For bare finger operation, space between adjacent connectors shall be not less than 25 mm (1 in), except where connectors are to be sequentially removed and replaced and 25 mm (1 in) clearance is provided in a swept area of not less than 270° around each connector at the start of its removal/replacement sequence. Space between adjacent connectors shall be not less than 32 mm (1.25 in) if the connector is to be operated with gloved fingers, 64 mm (2.5 in) if the connector must be gripped firmly, and 75 mm (3 in) if the connector is operated with mittened hands. Spacing shall be measured from the outermost portion of the connector, i.e., from the backshell, strain relief clamp, dust cover or EMI/RFI shield. Where high torque is required to tighten or loosen the connector, space shall be provided for use of a connector wrench.
Check out forum280.
JHG
The human factors MIL-Specs I have at my desk are
MIL-HDBK-743
MIL-HDBK-1908
HIL-HDBK-46855
MIL-STD-1472
I know I've seen something like what you describe in one of those.
--Scott
thanx for all the info on mil spec connector spacing question. that's exactly what i was looking for :)
