Modal analysis for unanchored tank
alishst
13
Hi
I'm trying to model an unanchored storage tank using FE software Abaqus. I wanna run a modal analysis and find out the frequencies for main impulsive and convective modes. However, I need some analytical equations for these two in order to verify my results. Is there any design code or scientific paper which could help me check my analysis?
I had previously checked API 650 for 2007 but it only has impulsive/convective periods for anchored tanks and doesn't give any separate equation for unanchored (or self-anchored in their own words) tanks. Which edition are you referring to?
For normal design purposes, the periods are assumed the same whether anchored or not.
I don't recall seeing anything on change in period with significant uplift. I would think somebody has looked into that, but not a standard design consideration.
