cirus76
- Jul 14, 2024
- 4
Hi. i have ran a modal analysis for an integral gear 3 stages compressor skid. the speeds of two rotors are 29121 and 42460 rpm respectively and motor speed is 3000 rpm. but the results was disappointing, there is almost 40 natural frequencies in the range of 10 percent lower and higher than rotors speeds which is not acceptable based on API. did anyone have the same problem? what should i do now? this amount of frequencies is natural?
