Hi everyone,
First time posting to Eng-Tips, so hopefully this is the right way to do it.
I am doing research on iterative solvers and would like to ask if there are any modular FEA packages out there. Let me explain. What I am after is something along the lines of Geometry modeller (optional) -> Boundary condition/Load processor -> Meshing routine (different elements ideally) -> Solver -> Post-processor. At every step "->" information from the modules should be exportable in some format (doesn't matter what, this can be taken care of with a custom piece of code) and importable to the next. In my particular case, I want to run the above pipeline up to and including the Meshing step, export assembled global matrices and load vectors and use them to get displacements from the custom solver I work on. These displacements, formatted appropriately should then go the Post-processor module to get stresses, strains, etc.
This might be a tall order, but I had to ask. Alternatively, a software which can work with externally generated displacement data would also do in a pinch.
Any suggestions are more than welcome!
